net_utils
st.net_utils.validate_ipv4_string(ipv4_addr)
Validate dotted-decimal IPv4 address string
Parameters
ipv4_addr (str) – address to validate
Returns
if valid IPv4 address, false otherwise
Return type
true
st.net_utils.validate_port(port)
Validate port number
Parameters
port (number) – port number to validate
Returns
if valid port number, false otherwise
Return type
true
st.net_utils.convert_ipv4_decimal_to_string(ipv4_integer)
Convert IPv4 decimal value to dotted-decimal string
Parameters
ipv4_integer (number) – decimal representation of IPv4 address
Returns
IPv4 value if successful, nil otherwise
Return type
converted
st.net_utils.convert_ipv4_hex_to_dotted_decimal(hex_ip)
Converts a hex string to a valid dotted-decimal IPv4 address
Note: This will be primarily used to update older LAN devices that have hex representations for their IPv4 address. This utility function could be removed in the future when no longer in use.
Parameters
hex_ip (str) – IP address string represented in hex
Returns
IP address in dotted-decimal form if valid, nil otherwise
Return type
str
